help! how to disable useles services?
[FONT=&quot]Recently, my phone is leaking power in a crazy speed. (i9100 4.0.3)[/FONT]
[FONT=&quot]Before sleep, I turned off bluetooth, wifi, 3G, gps, all motion sensors. Switched it to flight mode. After about 7-hour sleep, 10% battery was lost. This happened for the last few month.[/FONT]
[FONT=&quot]I installed DX BatteryBooster, from its monitor I learnt that almost all the power went to Android System, if click at it, it says included packages: [/FONT]
[FONT=&quot]Remote Device Management Service. [/FONT]
[FONT=&quot]Software update[/FONT]
[FONT=&quot]Video Maker[/FONT]
[FONT=&quot]What are these services how do I turn them off?[/FONT]
[FONT=&quot]Thank you[/FONT]
Hi aihenry2980.. ;)
Welcome aboard. Ten percent battery power overnight I would consider normal with these kind of smartphones. The way I see it, if you were losing Fifty percent of battery power - then you'd have something to worry about.
Enjoy your phone. Also, you might wanna check in with the other users of the same device for some good info, tips & tricks on your device.
P.s. Those so called "battery booster" does nothing more than drains the battery even faster.
Thanks for you reply.
When the phone was bought 7 months ago, only 1% battery lost overnight, really miss that time...
With the drastic background processes, the phone cannot last for 6 hours of daily use. it was able to last for a day.
I knew that battery booster does not save me any energy, all it does is turn off sensors and communication modules which i had already turned off. but i need sth to analyze power consumption, because the default system battery info app does not do tell u the detail within the "Android System" process. Do you have any lightweight battery analyzer app to recommend?
Thank you!
Hi aihenry2980.. ;)
Sorry! I don't know of any that I would feel comfortable recommending to you.. I really don't use or would suggest a member to do so. But if you think that it works out for you - you can checkout the Google Play store. :)
