Hi is there anyway to take an "image" or "clone" of your current devices state (OS/memory/etc...)
to be able to restore to it later in case you need to?
(like Acronis True Image (you can image or clone a hard drive) and then restore it to that moment at will)
is there anything like it for Droids?
we need it in case we mess something up - with some install or etc... or I partucularly need it to be able to get it back up and running when reinstalling the OS when abroad - see as per images I can't use it unless I activate it - but it fails if I'm not in USA - more info here - http://androidforums.com/motorola-droid-3/390002-help-activation-abroad.html any ideas?
Thank you...
Thank you...
