Pushing in the card did not make it pop out. However, I figured it out: there is a piece of plastic behind the SD card and on top of the SIM card. That plastic tilts up, and then you can pull out the SIM card. The metal piece that I thought might be a hinge does not move.
Yeah, the manual says to lift the cover but it's not a cover! It's more of a gap-filler behind the card, not above it.
It's annoying, isn't it? I read the manual before installing my microSD card, but I was still confused after I popped off the back of the phone. I felt like an idiot, because I couldn't figure what "door" they were talking about. The rubbery thing didn't seem like a "door" to me, but that is what they meant.
At one point, I lifted the flap and tried sliding the microSD card in, but for some bizarre reason, it wouldn't go into its slot. Not sure what I was doing, I released the flap and simply slid the microSD card in with the flap down. I hope I didn't damage anything when I slid it in at that slight angle. The microSD card works fine, so I guess I didn't.
Did someone else put the microSD card in there for you? (My Photon came without one installed.)
