[help] htc desire 601 won't turn on
dasojie
need help
my phone won't turn on after charge 8 hour...
when i charge isn't not turn off or battery drain issue. it's still 11% the i charge 8 hour and wake up i still can turn off alarm then few minute when screen off it's totally power off.
when i try to press power on it won't turn on or get to htc logo or hboot..
already try full battery out from device and wait for seconds, press power on and volume down in same time for 30 second, plug to pc use usb and still same won't turn on...
my device is use kitkat 4.4.2 and not rooted...
please help...
Are you sure that its charging? When it's charging, does the battery icon show the charging symbol in the center of it? If not, have you tried another USB cable?
