Ok I just freaked a little bit, it's back now. Got it plugged into the puter, I had no idea plugging it into the wall would charge it faster. I'll go and do that. Thanks yall!
Computer USB port rated at 500ma. Wall charger rated at 850ms. Car charger rated at 1000ma. I bought a spare wall charger on eBay for $2 to keep at work. I only charge with the wall/car charger unless you have it plugged in all night to the computer while you sleep, otherwise it takes forever and needs at least 5% charge to even turn on.
