just update manually. QDL Tool is perhaps the best way to do it, although there are some other ways. I wouldn't count on AT&T 2.2 coming up anytime soon. Thats why I put 2.2 on myself. Big difference.
the qdl tool is the best way to go. that way you get the unlocked 2.2 load so your phone works the way dell meant it to. att will lock down their load and remove things.
