Throw it in the trash can or is it fixable?
I wiped my Samsung Galaxy Note (Note 1) to the extent that now it says
"No OS installed are you sure you want to reboot?"
when I go back to the screen that shows the status of the wipe, it says;
Formating data using mke2fs
Done
Formating system using mke2fs
Done
Formating cache using mke2fs
Done
Formating emnc using mkdosfs
Done
Wiping android secure
updating partition details
EMount Unable to find partition for path '/'
...then it just repeats the last two lines above a few times.
I'd really like to keep the phone and NOT throw it in the trash can.
and when i try to reboot it says;
"Install SuperSU?
your device does not appear to be rooted. Install SuperSU now? This will root your device."
Kind thanks,
Eddie
Done
Done
Done
Done
"Install SuperSU?
Kind thanks,
Eddie
