Help Help: i5700 can not connected in usb debugging mode with pc?
buuquoc85
i try to hack root for samsung i5700,it needs to connect with pc (win Xp) in usb debugging mode,but i can't.i got usb_android_driver but it couldn't work.Anyone help me?
Or anyone know how to take screen capture ss i5700,pls help me!!!!
Thanks alot
Thanks alot
I can quote the reply from Samsung Sweden about this issue. I am assuming you want to use the New PC Suite (NPS).
What is it that you want to do with the phone connected?
When You connect you have to choose to "mount" the phone (in the notification bar on the phone). Then it shows up as a mass storage device.
I already knew what you mean . But i want to connect in the usb debugging mode ( Go to Setting -> Applications -> Development -> Usb debugging turn on).Because it's the 1st step when you want to hack root your android phone.When i turned on usb debugging mode and connect it to my PC (window XP SP3),it could not recognize my phone.I tried many android usb driver from internet but it could not work :( .
Restart your pc > stick usb first (Without connecting the mobile) > connect with mobile > should automaticly detect the drivers and install them else download android modem & usb drivers.
Hi. I m from Turkey. I have a i5700 but my pc is not see my phone, i want to usb driver, please a link for downloading. thank you.
