HELP, I'm halfway through!!
Mysterka35
So. Now that I tweaked my laggy LG G4c(Using ElementalX Kernel Manager, posts from xda and google+community) I must say that this is remarkable phone LOL. I feel like holding in my hands REAL LG G4 except this one is smaller, variety of apps available - slightly decreased. Heh.. BUT. Now.. I am not sure if I can change this but is it possible to AVOID FREEZING? Sometimes my phone freezes for some reasons. For example five minutes before I opened google+ app with turned off mobile data (nope. I don't have wifi router so mobile data is all sufficient.) so.. Everything seemed fine at first glance, but when I turned on mobile data - hello fre-fre freeeezing..... Although I many times calculated approximate time that my phone sometimes unfreezes and starts to work(varies from 20secs to 2 minutes) (definitely there are cases when I can't access due to frreeeeezzzing my phone at all) so.. I also noticed a few things:
1.During frrreeeezing my phone's battery drainn
improves slightly..
2.Heat. My phone starts faster to emit heat from upper screen
3. In most freezing states I can access power button. Yeah. I can turn off and turn on my phones screen. Very helpful indeed, as I have very good expression in my face seeing same screen on this freezing period.
4. At least if my phone freezes and there is PowerAMP running then I can listen music.
So. Is there any way to fix this thing? It really annoys me to take off back lid and remove/insert battery and restart my phone.
Is the only changes you made to the kernel? In other words, you didn't flash any custom os?
And if you just modified the Kernel, that might be your issue. Sometimes you need to play around with the Kernel settings to find something that works for you.
The issues you describe can definitely be a consequence of modifying the kernel. Either overclocking or underclocking can have side effects on device performance.
Obviously if these issues just presented themselves upon modifying the kernel, it's related. I would tweak the kernel settings. Just play around until you find a combination that works for you.
If all else fails, reflash the stock boot.img to at least get rid of the problems.
Well the whole FREEZING was before I modified my kernel, well I have stock ROM that is lollipop 5.0.2
But since I deleted bloatware and yeah am I rooted of course I can say that with this app my phone performs better than before. Still I will try tweaking it a little by little, who knows what impact may that cause
If your device has a custom recovery installed, I recommend making a backup of system, data & boot partitions. Play as much as you want. If anything goes wrong, simply boot into your custom recovery and restore that backup
Honesty there is only one thing I'm currently do play with. Because GPU, MEMORY I/O scheduler(not sure if this is how it is called under categiry miscellaneous) those three already at my phones peak, so only thing is CPU Governors stuff doesn't seem like this one can mess with my phone
