A
Andrew R
Guest
Right let's get this out of the way early: I'm a newbie but I'm going to try and not waste everyone's time
I'm new to Android. I have a Galaxy S5 that is stuck on 4.4.2. Every now and then at the lock screen I get messages along the lines of "New software available in settings" When I go to settings and 'About Device' and try and upgrade I get a message similar to "you are on the latest version etc".
This seems strange to me as there have been multiple updates to Android since this version which I believe is the version that was current when this phone was released? (Remember I'm new
) Should I be able to upgrade to a later version??
Ok here's some info that I believe is important
Model: SM-G900I
Version: 4.4.2
FIRMWARE
AP: G900IDVU1ANC7
CP: G900IDVU1ANC9
CSC: G900IXZA1ANC7
Other:
Carrier: Telstra
I haven't 'rooted' the phone or done anything exotic to it! I did buy it online through a commercial (not private seller). Appeared to be new but could have some 'history'
I've installed Kies and it's also saying the same thing as the phone i.e. you are up to date.
All up no real major issues except for Spotify not working and the phone being a bit laggy etc but just want to make sure I'm on the latest version.
Any advice greatly appreciated
Cheers All
) Should I be able to upgrade to a later version??Ok here's some info that I believe is important
Model: SM-G900I
Version: 4.4.2
FIRMWARE
AP: G900IDVU1ANC7
CP: G900IDVU1ANC9
CSC: G900IXZA1ANC7
Other:
Carrier: Telstra
Cheers All
