Help , in sd card
i really dont know, i dont own or have one available to see, but my suggestion is use an app from the playstore.
Go to settings --> Apps and tap on an app. there should be an option to move it to SD card. This is native Android functionality. The best apps that Ive found are Link2SD , Sam Lu's AppMgr lll (there's a Pro version for
Simple answer is you cant do it on modern android phones man. The external sd card is for media: pics, music, vids the internal one is for apps etc. I know the s4 is pretty low on internal storage so if thats a problem, youre gona want to look into rooting it :beer:
