pitotheface
Right now i'm running:
ClockWorkMod v5.0.2.7
CTMod 3.75.2 Final
Android Version 2.3.6
Baseband Version S:M820.07 x.FF19
Kernel Version: 2.6.35.14-PREVL-KK-2.5
Can someone point me to a guide to installing CM7? The ones I have found suggest that my baseband should be something older than FF19. I'm not sure if the newer FF19 baseband would cause a problem or not. I have just started playing around with rooting and such over the last couple of days. The "Dummy's Guide" to rooting the Prevail and installing CWM, CTM, and KK2.5 was really easy to understand, so I was able to get it right on the first try. Any help would be greatly appreciated. Thanks in advance.
CTMod 3.75.2 Final
