If the new agats FI27 is a safe recovery just drag n drop a CWM rom with CWM recovery on your SD card then boot into agat recovery n flash the CWM rom you will now have CWM recovery. to get the power button to work in CWM recovery you have to press volume up then down then up. now you can select w volume and enter w power button. IF you just want CWM safe recovery to flash a different rom download a repacked kernel w CWM recovery to you pc and w ODIN flash it n the PDA slot. Theres a kernel repository at XDA chris41g has a safe EL26 kernel w CWM recovery that every one uses to flash roms.
