Help installing ICS Domination v2.0.3 XILA UNIVERSAL
I installed Checkrom RevoHD V6 and then installed ICS DOMINATION CR1 via kitchenpro. I would like however to install ICS Domination v2.0.3 XILA UNIVERSAL but I'm confused as to the installation procedure. Has anyone installed ICS Domination v2.0.3 XILA UNIVERSAL and if so how did you go about doing it?
IIRC Its the same theme but it was ported to work with Checkrom v6. I tried flashing the XILA one before I knew about the one in the kitchen and it gave me problems with the market app.
Have checked the beginning of the thread on XDA for the ICS Domination theme and there seems to be a v2.0 for RevoHD. I'm just dubious as to the best way to install.
Yes its just an add on though, the file is only 7MB. It says to flash the XILA file first which is 38MB then flash the Checkrom file. I did this and I could not download apps from the market so I had to re-flash the rom. You are welcome to try it but I don't see the point when its the same theme as in the kitchen.
make sure you install theme restore package V2 before making any changes, all available in the kitchen, if only people took the time to read the thread.
