Hi to all, i got this issue with my Arrows X F-02E .
Believe me, ive searched everywhere and , i dont know exactly what my problem is, because the threads that ive seen, are so different from whats happening to me.
So well, like 6 months ago, my storage stopped working, i couldnt download apps, as my internal storage capactity reflected 0.0gb, neither i could take pictures or store anything, so well heres, what i consider to be the twist.
There are many things that suggest to me that the files are actually inside the device, first of all: clean master.
According to clean master my device has 18gb used, and 24gb free, what i remember to be exactly how my memory was way back, also if i run the cache cleaning on clean master it actually find 700mb or somethin, i havent run it to delete the cache because i consider something awful might happen.
The other thing, all my apps are still there, and i can actually use them, yesterday i was using skype, but i cant seem to update the apps, so well idk what is actually happen, and would appreciate any help.
Some other things to take in consideration.
I have never rooted the device, well not that i know of, i tried once but the device didnt appear on the terminal so i left it as that.
by that means i haven't tried to install a custom rom.
Just downloaded apps from the market.
So well besides an answer , i would like you to recommend me what would be the best course of action.
Because it would be so good to recover everything, but if it cant be done its ok, i just wanna consider what my options or option is.
Hope yall are having a good time, and thanks for your time
