Help HELP.. is it dead??
miseryguts
Can't turn on & no battery level indicator when it's plugged in, is there anything I can do..?
It is rooted but doesn't have a rom installed.. that means that I can't return to Google right..?
Thanks.
Try holding the power button down for 30 plus seconds without releasing it, report back
Not sure, could of been battery was too low and it went into deep sleep mode, I always make sure if it gets to half battery, I have the wife put it back on the charger.
Hey, much appreciated that fixed the problem.. any ideas what may have caused it?
Cheers.
