Hi all,
I've gone over my head I think. I tried rooting my s2 following instructions on shetalksandroid.com, all was fine until the reboot when the screen went black, came up with the first start up screen and the yellow triangle and then went back to black I'm on orange if that makes any difference but what I've tried so far is...
pulling the battery at various times (as its powering on, when the yellow triangle comes up, in recovery mode) - Nothing
I've done a factory reset hoping that it might spark some life but again failed
I've also tried and I not sure whether I should of done but I re did the root.
I can't get any power out of the phone all I get is the yellow triangle under the SGS2 logo.
In the dark last night I noticed that there is a back light on and the light sensor is flashing slightly - the red light at the top right on the framework, I assume this is the light sensor anyway.
Any ideas at all? I tried to find the original kernel to flash that back on but I can't seem to find it anywhere???
Any help is much appreciated, and as you can tell I'm a complete newbie.
Thank you
Thank you
