help - keyboard to...
InGearX
I often enter/email same text..
Might be just my cell # or might be my email or might be long text for an email explaining a certain procedure..
I'd like to easily output such often used text..
What are my best options?
thank you..
Hi
I think what you need to do is enter your text. Select it. Copy it to the clipboard. It will then be available there to be pasted into any text input field until the clipboard is cleared. The clipboard holds 20 different text entries on my phone. (Not sure if that is device dependant)
Roger
Try the messageease keyboard. I personally tried it and I loved it very much. It has a tap-drag and go function where you can save up to 9 items on your clipboard. All built into the keyboard.
It takes a little time to get used to it, I took a month.. But after that, I'll never use a qwerty keyboard again
+1 for Clipper. You can save any number of pre-typed amounts of text, and name them. Additionally, you can sync the pro version between devices, as well as having it retain a large number of previously cut or copied text
