Help looking for good live tv streaming (EU)
espressox
Hi
I am trying to find a GOOD app that streaming live TV and has a good range of European channels
I have tried various apps and generally they dont start up, cant connect to server or quality is bad
I have tried: Watch TV TV for android Online TV TV GOO,Play Live
I also tried FlimOnLive Tv which is the best and would recommend but want more channels
Thanks
I'm sure it depends on what country you're, as to what's available for live streaming. If you're in the UK or Ireland, you've got BBC, ITV, Channel 4, Channel 5, RTE and Sky. I think they all have live streaming apps for Android. Netflix also operates a UK and Ireland movie service for Android as well.
Some of the ones you've mentioned are most likely illegal, that's why they often don't work or the quality is bad.
BTW if you want to watch China Central TV live I recommend this one...
https://play.google.com/store/apps/...arch_result#?t=W251bGwsMSwxLDEsImNuLmNudHYiXQ..
