so... LOL! I FINALLY FIXED IT! so what i did was upgrade from lollipop 5.0 to marshmallow 6.0 using CM13. LOL. omg. took me 4 days of hard work, research and help from people like you to fix this.
Good deal, glad you got it sorted. Sorry I had to crash after my last post, barely kept eyes open for it.
Your CPU architecture determines which version of Xposed to use. Both of my Samsung's are the same as yours and I had found a modified version of Xposed that worked on them with stock deodexed 5.0
Determination pays off as well as research.
A few things to know(1) how to disable Xposed in case of bootloop or other issues, think of it as Xposed safe mode http://forum.xda-developers.com/xpo...-modifying-t1574401/post51306764#post51306764
Post #8979
(2) locate the Xposed un-installer zip for your frame work. Best way to un-install if needed.
I don't understand the need to be deodexed for xposed. I have xposed on 5 different devices... Only 3 of them are deodexed. Xposed works fine with odex ROM.
