Root Help! Lost CWM after manual update
Not sure what that problem is.
Try GooManager. Select flash rom's and it will say you need a compatible recovery. Tell it find one for you and let it install TWRP.
Its also possible CWM was overwritten by stock recovery. Look in your /system folder for a file named recovery-from-boot.p. If it is there, rename it to something like recovery-from-boot.pbak of whatever.
I'll give that a try. I got to to try and load CWM, but after the Google load screen all I get is the android logo with an open stomach and exclamation point inside a red triangle.
Anybody know what might be causing this?
I had that problem a lot. That's where you go to get to the recovery menu but the menu wasn't showing for me. I had to play with buttons and eventually it would show. I think hitting power and volume up for a second helped me.
You can also try this Quick Boot app. It works great .. if you have a recovery.
