Help, Lost my status bar!
are you using any launchers? Some launchers have an option to hide the status bar. On go launcher you just pull it down like normal even though you cant see it, and on launcher pro you hit the home button and it appears. I am not sure about other launchers. If you hit menu it there a preferences option? If so try looking in there to see if you have hide status bar checked.
Try swiping your finger down on the home screen to see if that pulls it down. ADW has that option.
