I have a Desire S and am getting the internal memory low hassle.
Running 2.3 and have moved all apps to SD that can be.
Problem is this is still leaving me close to when the message kicks in.
I'm using Cache Cleaner+ but it hasn't made a whole lot of difference.
I used a Sandisk utility to scan the internal memory and there is only a very small amount of space allocated to apps, the rest is classed as 'other' and cannot be viewed with the app.
I would like to know is there a guide on using the likes of Astro or other 'explorers' and what/where to delete to make room other than just caches.
Thanks
Thanks
