Pre-Installation
Please note: This tool is currently only available for Windows and Linux.
- Backup everything on your phone that you care about: Apps, settings, contacts, call logs, text messages, and so on. There are a variety of apps in the Market to assist with this.
- Setup ADB on your computer.
- Boot your phone normally and plug it in. Enable USB Debugging, place it in Charge-Only mode, and make sure that Fast Boot is disabled in your device's power settings.
- Make sure you have a stable, active Internet connection that is not via your phone.
- If you are on Windows:
- Make sure that HTC Sync, Doubletwist, and any other programs which may try to automatically sync with your device are uninstalled from your computer.
- Install the HTC Drivers package.
- Unplug and power off your phone. Remove then reinsert the battery, and power it on while holding down the power and volume-down buttons.
- Plug your phone in. If you do not see "HBOOT USB PLUG", select the HBOOT USB mode and confirm that "HBOOT USB PLUG" has appeared.
- Install the drivers on your computer. They should be located in the following folders (Make sure to check the "Include subfolders" option):
Windows 32-bit: C:\Program Files\HTC
Windows 64-bit: C:\Program Files (x86)\HTC- If you are not given a chance to select the drivers, open Device Manager, right-click on your phone, and select Update Driver Software, then Browse my computer for driver software.
- Reboot your phone back into Android, with USB Debugging still enabled, charge-only mode, and Fast Boot disabled.
- Run the following command from your command line, shell, or terminal to make sure your device is properly connected and recognized, it should return your device's serial number:
adb devices
As i said before, i have NO idea what adb is and what it is used about.
Don't smack me in the head but, is this all worth going through if he wants a screen record method vs. the screen capture method you describe SA?
Maybe I missed something??
Yah, I don't use it much but have had issues with adb seeing my device.........snipped quote
But, as I'm sure you are well-aware: USB / adb access on a Windows PC is (and probably always will be) "problematic" (that's being kind).
