Hi folks - I'm new here and hoping to get some advice on picking my first Android phone and carrier. Due to location, my options aren't stellar, but I've made lists of what I want from the device and what service is available from carriers in our area, along with some thoughts on plans, that should help narrow things down.
First, the carriers:
T-Mobile - only has 2G data, with an occasional pocket of 3G in places that I don't often go.
AT&T - has "4G" but it's really HSPA+ rather than LTE.
Verizon - has very good 4G LTE coverage.
Sprint - has decent 3G coverage, but only WIMAX as its 4G offering here right now, though they are are supposed to be rolling out LTE in the next couple of months.
Straight Talk - as best I can tell, in this area they piggy back on AT&T for GSM and Sprint for CDMA. It's hard to be sure on the latter, but I spent a while copying IMEI codes from ebay listings and putting them into their site and it seemed to like the Sprint ones but not the Verizon ones.
Next, the phone:
I want a QWERTY keyboard and some flavour of 4G, though I don't mind using 3G as well.
I want to be able to tether it to a laptop (even if that means rooting it or installing a 3rd party app).
My best guess is that I'll need 5-10GB of data per month.
Finally, there's plans:
T-Mobile's $70 unlimited offering would be ideal for me, if only they had a network in these parts that wasn't made out of cheese.
Verizon's $140 for 10GB is more than I want to spend and its Prepaid plans top out at 4GB, which is too low.
AT&T also want $140 for 10GB and it's prepaid plan tops out at 3GB.
Sprint has a prepaid plan for $60 with unlimited data (throttled do 3G after 2.5GB) and also has a $100 Business plan with unlimited data and 5GB of hotspot data that would be ideal, if only they'd completed the LTE rollout.
So, my thinking is that it might be best to do this in stages. Start out with a WIMAX device on Sprint (if I could get one cheap enough) on their $60 prepaid plan, then ditch that and move to an LTE device on their $100 plan once the LTE rollout is completed.
For the first device, with my wanting a QWERTY keyboard as well as WIMAX, I've been thinking of the HTC EVO Shift, which can be had for $20 to $40, if you time it right.
So, that's my thinking. Now, please tell me everything that I've gotten wrong.
Next, the phone:
