That means that there's a firmware update available but a lot of people are attempting to update and are in the queue before you. If you keep trying the update should download and install eventually.
what????? so its like 1st come 1st serve?? and its been like this since yesterday i think.... it wasnt like this before when i 1st got it cause i kept on pressing update and it will say like "latest updates has been updated"
You can skip it most of the time by using Kies
As shotgun says, theres a trick that can sometimes make it come faster or as gomjaba says you can plug into your pc and get it instantly but just now, imagine that youre in a queue and it will come sooner or later![]()
Run Kies then plug the phone into the PC with the USB cable and kies should recognise it and tell you theres an update available to download :thumbup:
Lol whats missing? What carrier u on?
for carrier, you mean what phone i have right? o.o if yes, my s3 didnt get the updated version of settings, the light effect on lock screen, multiple lockscreen widgets, customize message thing, the 2 finger toggle thing, smart switch widget, no white background from the gallery if i put the 3d thing, and lastly screen mode.
I meen like the network its on. Verizon, o2, t-mobile, ee, etc. I think some of the US carriers leave out some features in their updates. Did you get the multi-window?
