Root Help me out with this
jason1910
Im ON THE FRAMAROOT IT KEEPS SAYIN IM NOT VULNERABLE ENOUGH WILL SOMEONE PLEASE EXPLAIN WAT AND WHERE I NEED TO GO TO GET THIS TO WORK
I think you will get more help on the ZTE Awe All Things Root subforum so I moved this there.:)
Well your listed devices says you're using a zte awe, which is not a motorola phone by any means. So what phone do you have? If its a Zte Awe then the link that DsyMnapTic provided you with, is exactly what you need. If you are not on a Zte Awe anything in these threads can potentially brick your phone. If you give me the model of your phone, I will point you in the right direction for what you need.
i put it on wrond forum ..i have both awe is cm 11 and i use all the others to i switch roms every other day...but this dx2 killin me not having root cause no p.c and as all of yall know thats a whole different thing
that link for root with out pc for the awe i used that same apk on two tablets which were diferent brands use at ur own risk
