1. if you're not running Amon RA as your recovery, i would switch to it...
it can be found
HERE. don't forget to rename it to PC36IMG and flash it via hboot.
2. i use VR Superwipe, found
HERE.
3. i would recommend MikG 2.5, found
HERE.
4. download the 2.51 (with kernel) and 2.52 patches also.
5. place 2, 3 and 4 on your sd card.
6. perform a nandroid with Amon RA.
7. wipe data, cache and dalvik-cache ( i wipe 3 times )
8. flash VR Superwipe ( i flash 3 times )
9. flash MikG 2.5
10. flash 2.51 patch
11. flash 2.52 patch
* i flashed the rom and the 2 patches in the same recovery without any issues
12. reboot
