Help Help me please
  • Thread starter Thread starter Cant get to home screen
  • Start date Start date
C
Guest
I downloaded Phil's touch 6.44.9 I didn't know what it did but when I entered factory mode it wasn't the same instead of the normal one it was Phil's touch. I clicked reboot system went to the load up screen then went back to philz touch 6.44.9 I can't exit it no mater what I do please help me!
What's "Philz touch", a custom ROM that doesn't work on your device? To fix it, you'll have to re-flash it either back to the stock manufacturer firmware, or find a correct and suitable custom ROM for your device. :thumbsupdroid:
Hopefully you haven't irreparably bricked it, otherwise you might be sending it back for flashing..$$$...or even buying a new device....$$$$
