Root Help me suhel in app2sd
uzumaki17
i'm now longer installed app2sd
i'm open cmd
i type
adb shell
sh
sh /sdcard/app2sd.sh
and in cmd write " sh cant open /sdcard/app2sd.sh "
Help meee alllllllllll
i'm open cmd
i type
adb shell
sh
I suggest you to use your phone and use ScriptMe instead..
Scriptme is freely available on market
Thanks To Nick for pointing out the glorious application
i'm open cmd
i type
adb shell
sh
hi uzu....i also experienced that many times when i tried to re-install app2sd after flashing....i just rebooted my pc, rebooted my phone, and connect it again to pc....make sure sd is not mounted....
just try and try...you'll get it done...:D
i also get this error.
after partitioning, i unmount, my phone detects "Blank sd card" even though i transfer all my data already. I ignore it, continue the steps
"Connect your phone. Make sure Usb Debuggin is on.
Open Dos prompt (Start-Run-Cmd)
type adb shell
than type su Quote:
then type
sh /sdcard/app2sd.sh"
but can't open :(
i tried rebooting still does not work.
There's a common bug with app2sd installation. It's the "users" bug.
Please note that in order to install app2sd, your sdcard needs to be visible to your phone, not to your PC.
Can you browse your sd card from your phone? and if you can, did you find app2sd.sh? And if you did, was it in a different folder than NO FOLDER (not ROOT, not SDCARD etc).
If these check out, then do you get the '$' prompt after you start adb shell? If yes, do you get the '#' prompt after you type "su" and allow superuser from your phone (by clicking YES)? If yes, I'm very curious what the problem is if it still doesn't work!
what if u cant browse sd card? mine shows "Blank SD card" after partitioning even though i transferred all my data in :O
Also you may have a problem with the SD card. Some don't suport another file system then stock. And if this is the case, it's bad news because even if you get it to work, it could corrupt data.
waaa... IM new to this... When I type adb shell this always appear on prompt.. 'adb' is not recognized as an internal or external command.
