Help me with my BRICKED WARP ZTE
Delta9
I have a ZTE Warp N9510 with philz on kitkat that is bricked. Heres what I did. I rooted it using kingRoot. Then I overwrote the recovery, I had issues booting into my phone, Id only get the green android screen and it would just go black but the screen light was still on. I put it in some mode, idk how I did it, I was holding the power button down along with both volume buttons and I got a white screen with three letters on it, i dont remember the letters. I was able to use an unbrick tool then a CMW and root tool to turn it back on, and it worked. I tried formatting everything in philz such as the system, cache, data, ect. Now I cant get into my phone at all. I dont even get the green android boot screen. When I put the battery in my phone and try to turn it on I just get a red light on the top of the phone. How do I fix this? Unbrick and root tools dont detect the phone, I cant get it into DFU mode or any other type of recovery mode. What are other boot modes I could try to get into on that phone.
I have the same phone on Boost Mobile. 1st you don't hold both up and down volume controls and power to get into recovery boot mode. I can't test it right now because my primary isp is down. I am on my auxiliary isp via my cell phone plug into my laptop. Anyways if I remember right it is hold volume down and power at the same time to get the recovery boot mode. I am not 100% positive but I think KingRoot is were you messed up. Mind you I am a Windows pc tech not Android. I am still learning Android. But with the right help and precise written directions. I got my phone rooted and I didn't have any problems until now. The problem with my phone now is age. It needs to be replaced. Anyways I used the CMW rooting prog that is made just for the ZTE warp 4G N9510. I can dig up the directions that I have if that will help. Just PM me your email address and I can send it to you.
Steve
When I try to mess with my phone I just get a flashing red light when I try to enter some other boot mode. The screen stays off and nothing happens
@reble ill send u a pm now
Delta9 I don't see your PM to me. And by the way it is volume down and power at the same time to get into recovery mode.
Delta9 wrote "
@reble ill send u a pm now"
Are you talking about the linux distro stliaz? And I dont think you understood that I flashed the kernel and there is no bootloader on my phone. If i try to boot into any mode I just get a flashing red light
If you have a PC you can try the zte warp recovery. Found on this site. If that don't work you prolly have hard bricked it and is done for. Iv had 2 of these do the same thing that you've described. Good luck.
