Root help.... miui back to gb 2.3.4
shemslocum
Member
I have a problem with miui. I can receive txt msgs but when I send them the recipient gets a blank txt. I think this is due to not following the flashing instructions to the t. I tried clearing everything and flashing the eh09modem still not working. So I need to know if I can just use the Samsung simple dl to flash right back to the stock TB or what should I do.... ????
clear your dalvik cache via CWM recovery. See if that helps you.
If not I'd flash all the way back(odin) to 2.2, then the deodexed 2.3, then run the awesome sauce. 10.3. It's really pretty good.
