Help HELP! music coming front speaker
nemster
My music players, YouTube, and videos playing sound through front speaker. Help. Is it supposed to be that way? Is there a setting or do I need to return my phone. Pretty sure it worked last night. Thanks in advance
It's doing it with games also
Nevermind its working now. I rebooted. Maybe something got shut off when I cleared memory. Thanks again
Mine is doing this pretty often and is also corrected by reboot. The main problem is that when I use the phone as an alarm the sound is weak from the front speaker. I've been late for work twice already by using the phone as my only alarm. I should note that my Samsung Infuse did the same thing.
So I'm having the same problem.. If figured out that it occurs when I have connected my phone to my car via bluetooth. The only way to change it back is to restart the phone. Has anyone figured out why this is happening? Is there a common app that we have that is creating this problem? Please update this thread if someone finds a solution.
Could you provide us with a little more info about which version of the S3 you have? Knowing the model number and the build number could be helpful. It sounds like a pain, but performing a factory reset could be a possible solution.
