Help Help-My 3G isn't work..Networking isn't working
njtexas
hi--I'm not sure what I did, but my 3G isn't work. I have a Droid Incredible 2. For some reason as of Friday, my 3 G doesn't work. I can use the phone. I can also get emails and use the apps/internet when I use wifi. However, when I'm out and about, I can't receive emails or go on internet and use some of the aps because it can't find the network.
I just went to Settings. Then I clicked on "Wireless & Networks". Then I clicked on Mobile Networks and clicked on Data roaming-still nothing works.
Anyway, what do I need to press to get my 3 G up and running again---as I need to be able to receive and send emails when I'm out and about away from Wifi
Thanks!
I am assuming you are on Verizon? What have your customer servic said or did you get referred to a tech dept? Do you have access to another device and see if its performing the same?
Are you rooted? It sounds like it. I had the same problem a couple of days ago. If you are rooted, what Rom are using? It wasn't working for me with MIUI, Virtuous Unity or Newt's HD Rom.
