Root HELP MY idiot Friend destroyed my Rooted Marquee
IT runs ctmod perfectly. He uses for a few days, now thier is no radio reception. when I force roaming, bars appear with triangle. Please help me. I thought of Prl or profile issues. Idk how he did this. this marquee is an original boost phone. never flash to another network. Maybe profile issues? or prl?
And the unknown terror claims another victim. Yeah follow wetbikers advice. There are also some comments about this in the main CTMOD 3.80 thread that might help you if that fails.
If you still have issues with the roaming after doing what I mentioned above, give the Megatron ROM a try.
is happening to me as well and no one has touched it for two months! its been inactive for the time being and i even took it to the store they said i owed so i payed and boom still tha same shit....ugh gonna flash to stock on of these days...
You "owe"? Do you know when your payments are due?
that wasn't the problem, the main problem was i had to update my profile, i still have to, its something that i really cant seam to get a finger on though...
