Help Help!My nexus one reboots repeatedly!
jaylsc
My nexus one reboots and stop at the "x' screen repeatedly. Then,I back up my rom and wipe all the data.
Now,when I try to use rom manager to restore the data or rom. it reboots and stop at the "x' screen repeatedly.
That seems having some troubles in the data.
Anyone know how to restore it?:confused:
Thx for your attention.
If you are trying flash a rom. I would suggest wiping your data and cache/dalvik cache at least 3 times before and after you flash. then reboot.
