Hi there
First of all, I just wanna mention that this is my first Android phone and I'm very happy with it (used to be a BB user, then an iPhone user, and now Android)
However I did notice that my phone tends to get warm in the lower part (backside). I googled this and came across the following article
Samsung acknowledges Galaxy S3 heat-related issue | Ubergizmo
So naturally I started to panic. A friend of mine (Android user) told me that it's normal for a phone as powerful as the S3 to get warm when I'm using it. However, I have never had this issue with the Blackberry or the iPhone so I'm worried I got a faulty unit
I have installed the app "Phone Overheat" to keep an eye on the phone's temperature. So far, the temperature has been fine and tends to get around 38 degrees Celcius when I use apps such as an emulator while other 3-4 apps are open in the background. What has me worried is that I can still feel the heat through the TPU case I'm using.
So please tell me, is it normal for the S3 to get a little warm, especially in that area? When should it start to become a concern?
Should I return it and ask for an exchange? I've had the phone for less than a week
