hechtd
OK Guys, I have searched for a thread of this nature but have not found one under help and support.
I have a Thunderbolt, it's rooted with Revolutionary and I am running ROM Manager, (I bought the full version of ROM Manager FYI). I have several complete backups that I have run with ROM Manager and Titanuim (I paid for that as well). I rooted the phone in November and it was a perfect root no issues at all.
Now, my issue is that the phone will not connect via USB to my PC runnning Windows 7 Ultimate (32 bit) or my laptop running Windows 7 Home (64 bit). I have installed the Sync Manager (which should have the proper USB drivers for it to connect).
I went back and uninstalled my apps one at a time to see if one might have messed up my USB Connection. I have tried all of the connections to PC under Connect to PC in Settings. I even booted the phone with it connected to see if it could see the PC in the boot manager. I have had no luck at all. Can anyone tell me if there is something stupid that I am missing?
My phone is not bricked in the literal sense, I can still make calls access the internet, get WIFI and e-mail and its 4G LTE works as well, (occationally I need to remove and replace the battery to get 4G to run if it stops). I was able to connect to my PC's with it after I rooted it. I'm just not sure when it stopped functioning normally.
I am running the phone with several an extended batteries. One is a 3500 MHZ and one is a 4500 MHZ. (I don't like to run out of Power)
The specs for my Thrunberbolt ADR6400L are:
Android verison: 2.2.1
Baseband version: 1.02.00.0103_2r
Kernal version: 206.32.21-g2447a8d
htc-kernal@and18-2 #1
Build no: 1.03.605.10 CL313761 relase keys
Software no.:1.03.605.10
Browser version:WebKit/533.1
PRI Version: 1.41_002, 1.64_002
PRL Version: 15098
ERI Version:5
I have tried several different USB connections, all of my USB Ports on my PC's (front and back) as well as insured that USB Debugging is on.
Is there anyone out there that can lend me some assistance at all?
Thanks
PRL Version: 15098
ERI Version:5
Thanks
