Help need! How to download app using data connection?
waiwh
How can i download apps by using data plan? As sometimes doesn't have wifi access, but need to download apps. But it always prompt me " Download size requires WI-Fi" , even just a small app. :(
That option is NOT tick!
I had a look, the option is about market updates only when the phone is on WiFi.
But the option is only with the new Market app on my Android 2.3.4 phone.
Not with the old Market app on my 2.3.3 phone.
Harry
In this thread:
http://androidforums.com/motorola-droid-3/384071-download-size-requires-wi-fi.html
it says to:
Check your data saver setting under
setting/battery & data manager
That is how Verizon "helps" you not exceed your allowance under the tiered data plan.
If you have data saver turned on, large downloads will be deferred until you have a WIFI connection
I do not have that setting on my phone, but perhaps you do and it is what is causing the problem.
In this thread:
it says to:
Ok... un-check the "Data saver". Problem solved! Thanks all for the guide & advice!
