Help needed asap!!!
shayanabc
Hi,
this is my first forum post here and I really have a big problem...
I installed a custom rom with rommanager and if I turn on my phone it says touch the android to continue but when I touch it nothing happens
So I wanted to install the original rom I backed up but that is not possible because everytime I go to Hboot and try to open ''install from .zip'' or something in clockworkmod it just shows a black screen and when I hit the power button it goes back to the option menu from clockworkmod, Now I tried to do the things for slcd screen and everything but it doesnt work, when I put the update.zip on my micro sd the Hboot says ''checking sd card... no image or wrong image!'' so I changed my micro Sd card and now when I get into Hboot it just says nothing and when I click on recovery still black screen and not working I really need help asap!!! so is there a way to install my backed up original rom on my htc wildfire with my pc or a way to get clockworkmod working??
Please help asap!!!
Thank you
