Help Help Needed: Nexus 5 install button unresponsive
Fr0z3n
When I go to install an app from a screen like this
When I tap the install button it doesn't respond (it doesn't even have the light grey colour to show you are touching it)
Does anyone know a way to fix this or another way of installing apps?
Running android 4.4.4 but was having problem before I updated
Is it every app only that one? Also, if you open an app and try to use the screen where the install button is, is there any response?
