Help needed with position of day/date
Please forgive what's probably a ridiculously simple question.
On my S3's home screen, the day/date appears to the left of the time.
I would like it to appear beneath the time, the way it does on the factory default lock screen.
Any help?
Thanks.
Michael
Don't own my SIII yet, but it's a widget called Clock (digital) in your widget list. Have you tried tapping or longpressing on the clock to see if there are any edit options? If not you might try adding the widget to another screen to see if edit options appear when installing. If no edit options there either, looks like that's the only format for that widget. You can always delete the 2nd clock widget by longpressing and swiping it off the top of the screen or dragging it to the trashcan.
I got my Verizon SIII yesterday, and I do not see any way to change the position of the date on the Clock (digital) widget.
