I rooted my coolpad and tryed to install a custom bootloader. Now its stuck in a boot loop. God I hate metro pcs SOOOOOOOOOO MUCH. **** THEIR LOGO IT BLOWS PLEASE HELP!!!!!!!!!!
what did you do? all you have to do is use rootexplorer and rename the bootanimation.zip in the system/media folder to bootanimationorig.zip and paste your new one in there. Ive done it 6 times now, try using ADB drivers and restoring your file via USB and PC.
I used an apk called absolute system root tools I think. it was saved from my lg optimums last fall on my sd card. when I set the animation I tried rebooting and nothing it just says cool pad quarto and wont load the crappy metro logo. also my pc wont read the driver it just says this device wont start. I tried hard rest at least 30 time with sd with out sd with sim with out sim and still nothing the best I can get is using the update from sd card. The problem is every time I try to restore the old boot-loader it says error e signature cant be verified. Ill try renaming the boot loader like you said. Thank you. do you happen to have a link for the driver? I need one bad my computer might read the phone if I re install the driver. I haven't been able to find it but I haven't looked that hard either I've been busy fixing a morning call error on my lg motion. I don't have internet access in case you are wondering why I am having so much problems with this. I have to use the internet cafe and when I figure out what to do I pay my friend like $5 to download the software for me. In any event thank you. Ill try renaming and let you know
I have a coolpad Quattro 4G and my phone got rooted over a month ago. For the past 2weeks my google play store has been force closing every time i tap on it. i go to settings and clear cache and data but it still doesnt work. Even when i go on MetroWEB and try to download something it says the samething it says when play store doesnt work. Also my music app (the one thats on phone when you buy it) says, "this app is not installed on phone. Almost all my apps say that. I just don't know what to do. please help me.
If you want to chance a factory hard reset that might work or it might brick your phone in a boot loop. Instead what i would do is go to developer setting. Turn on the install non maket akps then try either downloading
Diffrent market like SLIDE ME MARKIT OR THE BLACK MARKET. If that dosnt work borrow someones droid and down load another market apk and save it to the sd card put that sd card in your droid and use astro or what ever file browser you got to,reinstall.i hope this helps
