help needed
dcalla41
I'm trying to follow this tutorial I found online. It says I have to change the name of the layout xml file. So I've changed the name to status.
The tutorial says that renaming the file requires me to change the name in the java file to refer it via the R class and that this is to be done in the StatusAactivity onCreate.
Where do I access this?
What device and what are you trying to do? Is this a rooting question?
Your resources are referenced in the "R" class which is generated for you automatically if you're using the Eclipse tools. You can open it and edit it like any java source. Look for references to the layout file and change them to status.
