Help Help Newbie here
HI all Need a little help
Just gave hubby a flytouch 3 2.3 android tablet and seems to be working fine other than a few little issue which I am hoping someone can help me fix
1. the sd card that I have put in says "preparing memory device" but then says "memory device ready to be removed" and I cant access it at all The tablet itself is 8gb and the sd card is a 16gb and for the life of me I cant work out how to get it to work
2. The other little issue is my husband has a HTC desire phone and loves playing Bunny shooter but for some reason I cant get bunny shooter to work on the tablet it loads and I can access the scores, credits and shop but as soon as I press start it freezes and I need to turn of the whole tablet and restart it just so I can get back to my main screen.
If anyone has any ideas on how to fix these I would greatly appretiate it.
Cheers
Aussie
Cheers
Aussie
For point 1 take the tf card out of the tablet, place it in a PC, format it with SD Formatter http://www.multiupload.com/L04B5BBK66Then copy a small file to it..it is not important what the file is...just make a small .txt file and copy it to the tf card and then try it again in the tablet... I believe the problem is caused by android not being able to see/create the two administrative folders (Lost & Secure) on the tf card.
For point 2... can't help you, if you can post the .apk somewhere perhaps someone can try it on their tablets.....
For point 1 take the tf card out of the tablet, place it in a PC, format it with SD Formatter Multiupload.com - upload your files to multiple file hosting sites!Then copy a small file to it..it is not important what the file is...just make a small .txt file and copy it to the tf card and then try it again in the tablet... I believe the problem is caused by android not being able to see/create the two administrative folders (Lost & Secure) on the tf card.
This worked briliantly for the sd card thank you so much !!!
As for the bunny shooter game I just downloaded from the android market first tried the free one then thought I should try the paid one so I brought it but still the same issue but on the HTC desire it doesn't have an issue at all so any ideas out there would be fantastic.
The good news is.......it's not your tablet being faulty as it does the same to mine!!
The bad news (if you want to play it on the FT3) is possibly this requirement..
PHONE CALLS
READ PHONE STATE AND IDENTITY
Allows the application to access the phone features of the device. An application with this permission can determine the phone number and serial number of this phone, whether a call is active, the number that call is connected to and the like.
Is really strange I have tried other applications that say they need the phone calls thing but they work fine must just be the application if anyone else has any luck with it could you let me know as Husband would love to be able to play it.
Cheers all thanks
Cheers
Aussie
Your ist issue is solved great for your second issue
download it in a usb drive install this and report back
Bunny Shooter v1.0.5.apk
Before installing don't forgot to activate unknown sources in settings/application
