A friend of mine has a problem that when in a phone call and is asked to 'enter code' say for a car park ticket. There is no back key to correct mistakes so she has to ring off and start again.
The problem is that while in a call and numbers are pressed, they are sent immediately. Even if there was a back button, it wouldn't allow you to 'fix' and incorrectly entered code.
If you dial the same number you can add the code after the number. For example if the code is 12345 followed by the # sign and phone picks up in 3 seconds. You set the speed dial to (555) 555-5555,,,,12345#
The commas represent a second pause. You may need to tweak the pauses if it's too quick.
