help. No command error Manual mode
  • Start date Start date
A
Android Question
Guest
Samsung Galaxy s4 through bell
Goes in to manual mode and the android symbol in the middle of the screen says error followed by No command
Below it, it says
# Manual Mode #
-- Appling Multi-CSC...
Applied the CSC-code : BMC
Successfully applied multi-CSC
Woke up to this. My phone was working fine last night
Try turning the phone off, waiting about a minute, then turning it on again.
If that doesn't fix it, go to the nearest Bell store, tell them that you suspect that they sent your phone an update and it caused a problem, so you'd like them to fix it.
If you don't get anywhere, pronounce the employee's name to make sure you have it correct, (ask for the last name if it's not on the tag ["Why?" "For the lawsuit, of course."]), mumble something about "lawyer" if you haven't mentioned one yet, and "ancillary damages" as you start walking out. The manager might wish to talk to you about getting your phone working by that point. (Unless he's starting a new job for the new year and doesn't care about his current one.)
