Help Help! Not receiving text messages
I was receiving text messages, but then all of a sudden, they stopped. I haven't downloaded any new apps. I am able to send them, but not receive. Please help. Thanks!
try using the smstomailbox app. it will send texts to your email. hopefully this isn't the same problem that was on the gsm hero...
i would try resetting the phone, i had a htc touch pro that occassionally had this problem, did a soft reset and it was fine.
i had this problem last nite, but i think wat caused it was that i switched my mobile network connection to EVDO ONLY, and when i switched it back to HYBRID i got bunch of msges at the same time... not sure if thats wat the problem was but thats wat happened.. it works fine now..
I havent recieved a text message ALL day, and i was starting to get worried. Now i had a free moment to search before i left my office. Thank you sir!
Remember folks you need the 1x to get you text messages!!!
This seems to be a pretty widespread issue. Does anyone know if HTC/Andorid are aware of it? Anyone know a good tech support number for HTC in the States?
