Help HELP! Notification Sound Not Working
Old Member
Android Expert
This morning when I took my phone off of charge I noticed that I would get a text and it would vibrate but not give me an audible notification. When I open and close menu's I can hear the click that is associated with opening and closing menus. My phone will ring when called.
I went into the sounds menu, opened notifications, when I make a different choice from the default sound I don't get a preview of the sound at all. When I go into ringtone and select a different ringtone, I do get a preview of the new ringtone.
This is definitely isolated to notifications which makes me wonder why and how to fix it. I can't find a volume for notifications only.
How about power off the device and power on again without the cord in the device
I tried that. Sorry I forgot to include that information ;) I also tried turning off Motorola Assist "Sleep" thinking it must be muting them still.
Try ... https://play.google.com/store/apps/details?id=com.firestorm.vc&hl=en ... to finally get control of your volume controls. I use Volume Control + Pro on all my android phones.
... Thom
Giving it a try now. I'll report back!
I suspected a buggy app on your phone. I would have suggested a next step of loading it in Safe Mode and see if it solved it. If it did then you would for sure know you had a bad app.
... Thom
