[Help] O+ 8.31 (Bricked)
benzondc25
Help guys, my o+ 8.31 is not
turning on, when I connect the
charger the phone not chargin
even when i connect it on
computer still nothing happen,
and no device showing on the
computer. The key combination
(volume + power button) is not
working. I think my phone is
Hard Brick. Theres any other
solution except using USB JIG or
JTAG?. Please help me. Sorry
for my bad english.
Hello and welcome to Android Forums benzondc25. :)
If your phone isn't charging and won't turn on, it could be that the battery has completely discharged. It's very common for charging cables to stop working and charging (usb) ports to break. I would first remove the battery, make sure the contacts are clean and then try charging with a different charger/cable. If it still doesn't show any charging, then you might need a new battery.
